Wantedl Brake Booster / Servo - Skoda 120gls
34 příspěvků (zobrazeno 1 až 34) od 12.12.2014 do 13.01.2015, založil/a Christopher
06:11:27
13.01.2015
13.01.2015
Christopher
Ok - thanks. I'll ask my friend if he's looking for one still. I'll get back to you shortly.
11:14:18
05.01.2015
05.01.2015
...the older model has different main brake cylinder (different piston and different distance between piston and brake booster...
11:11:50
05.01.2015
05.01.2015
Difference between older (left) and newer (right) "button"
11:10:34
05.01.2015
05.01.2015
11:10:01
05.01.2015
05.01.2015
11:09:21
05.01.2015
05.01.2015
-> Christopher: I´ve bought that booster for 500 CZK (about 25 CAD). It is new, but there´s been some rusty brake cylinder mounted on it, so the top is a little bit rusty too.
Also there is missing the vacual valve.
And it is booster for older model, so one part have to be replaced before mounting the booster to newer ("M") model.
If you´d like, I can replace that part and try to get somewhere that missing valve.
If you wouldn´t, never mind - I´d put it to my spares
07:39:29
05.01.2015
05.01.2015
-> Christopher: Good to hear you got it fixed.
The black hubcaps have two holes bigger than the other two - ie you can fix the wheel to the hub with two nuts, then put the hubcap on and then put the other two nuts on, fixing the hubcap as well... the nut caps are there just for aesthetics/protection.
Hopefully that makes sense
07:30:43
05.01.2015
05.01.2015
Christopher
Thanks Bukaj for the offer - I don't think I'll need it now, though if the price is right, having a spare is never a bad thing. Also, I know someone here who says he needs one for his 135. I can ask him if he's still after one.
Please e-mail prices here or at skoda@skodacanada.ca
Take Care,
C
Take Care,
C
07:27:58
05.01.2015
05.01.2015
Christopher
Hi,
Yes I did - it was the vacuum hose. The hose was newer, BUT at some point it had been crushed in the middle (maybe a rock - dented the protective plate). Fixed - nice and cheap. Thank you for the suggestions, help and ideas - if I had known it was so easy it would have been done some time ago!
One other question - maybe not a good one - with the black plastic hubcaps for the factory steel wheels - do they fix under the bolts (the bolts hold them on) or over the bolts (the black plastic bolt caps hold them on). Sorry, I'm used to the usual 'dog dish style caps'.
01:37:08
26.12.2014
26.12.2014
-> Christopher:
Hi,
so, have you any new discovery about your brake malfunction?
I asked Pavel Krejčík (you know him, as I learnt from him), but at this time he hasn´t any booster at stock.
So I´ve bought the brake booster for older model of 105/120 - if you´ll need, I can rebuild it to fit to your car and then ship it...
Hi,
17:27:19
17.12.2014
17.12.2014
Christopher
Thanks again for all the help.
Bukaj - makes good sense - easy to test at home, the only problem is finding a hose long enough - but I'm going to try in the next week (so busy with work, but vacation starts on Friday).
I have a set of 'Apollo' alloy wheels from the UK - these were standard in silver, black or gold on Rapids sold here. We never really had those black plastic center caps - many other options were used. Here is a pic of the definitely non-Skoda wheel covers the car came with from the Canadian dealership back in 1986. I still have them.
00:29:28
16.12.2014
16.12.2014
-> Bukaj: Ty taky nejsou špatný. Brácha je měl na oranžový před Apollama v barvě auta a černý ty prohlubně (už to tak bylo od předchozího majitele). Ale tyhle se mi líbí trochu víc. Za ty dvě stovky, co je autobusák nabízí, bych mu je klidně i koupil, kdyby to šlo poslat s tím posilovačem brzd.
-> skodoukolemsveta.cz: To je pěkný, ale mášs sebou dost dílů, který bys mu tam nechal?
Předpokládám, že zrovna posilovač brzd asi náhradní nevezeš, to je docela neskladný díl...
Předpokládám, že zrovna posilovač brzd asi náhradní nevezeš, to je docela neskladný díl...14:52:54
15.12.2014
15.12.2014
skodoukolemsveta.cz
Ahoj,
také se chystám do Britské Kolumbie, ale zatím jsem v Austrálii, takže to bude chvíli trvat, nicméně počítám, že Christophera tak jako tak navštívím.
Do té doby bude jistě potřebovat zas něco jiného...:-)).
Ivan
Ivan
10:03:41
15.12.2014
15.12.2014
-> dna69 - "zde je místo pro Vaši reklamu" :) 15.12.14 09:42:11: If plastic covers, then only the GL original ones
09:54:31
15.12.2014
15.12.2014
-> Christopher:
The best way to test, if the hose is good or not is to disconnect it from the booster (beware of the plastic back flow valve - sometimes it´s hard to pull the old hose off, so carefully - it´s better to cut open the hose and then shorten it a little bit than damage the valve
) and with engine running test its suction function with thumb.
Or you can test directly the booster by connecting any hose of right diameter (not any, it have to be self supporting - but it can be ordinary 1/2" garden hose ;-) ) to it and the second end of the hose to the engine intake inlet, then start the engine and press the brake pedal and you´ll know...
The seat material you´ve mentioned is one of the less durable one (is very sensitive to sunlight, so the top of rear seats is mostly damaged) and as it was the most luxurious (GL - Grand de Luxe
) version, most of the Skodas with this type of interior were exported "to the West" and although they are not so rare in Czech, only few of them have seats in good condition...
So it is almost unreal to get that upholstery in good condition, let alone brand new...
) and with engine running test its suction function with thumb.Or you can test directly the booster by connecting any hose of right diameter (not any, it have to be self supporting - but it can be ordinary 1/2" garden hose ;-) ) to it and the second end of the hose to the engine intake inlet, then start the engine and press the brake pedal and you´ll know...
09:42:11
15.12.2014
15.12.2014
-> Christopher: It's nice car! But if you haven't alloy wheels, you need this at least:
07:26:12
15.12.2014
15.12.2014
Christopher
Thanks very much.
If I was in Europe, I'd be happy with a used part, but since shipping for old or new is the same, I may as well pay a bit more for new. That Skodacanada e-mail is good - or ctrevelyan@telus.net is better.
I'm not 100% sure about the part - my local mechanic (who happens to be Czech) suspects it - the problem is bringing it to a garage and then having it sit for a month waiting for a part. I'm definitely going to check out that hose though this week to make sure - the car is very original (had original 1986 Barum tires when I bought it - and when I changed the plugs shortly after buying it I discovered the old plugs were made in the GDR/East Germany!), so I think the hose is original too.
One thing I'd love to find is some of that terrible black w/white stripe seat material. It's still ok, but it's getting old.
This was a weekend/fun car only, but I use it even less now that I have two small kids...but it's my last Skoda and I'm not quite ready to sell. One more pic at a Mercedes show...
23:11:24
13.12.2014
13.12.2014
-> Christopher: That link is to car scrapyard near to my city, so thats used part. I can buy it there (price is about 10USD), but I haven't any. They are selling operational parts, but new is new. I've posted that link to make sure of which part we are talking about.
I haven't many experiences with buying these parts, therefore I leave that to my friends Bukaj and Dragon. I know them and they are reliable people.
20:33:20
13.12.2014
13.12.2014
-> Christopher:
Well, I´ll try to get the new one as soon as possible and then I´ll write here, or to your e-mail (if this skoda@skodacanada.ca is your e-mail adress).
And, by the way - don´t you, or anybody of your Canadian Škoda community, need any other spare parts? When we will ship more parts in one box, it would be more effective and economical, wouldn´t it be?
P.S.: I´ve got one more question - are you sure, that the wrong part is the booster? More probably it would be the suction hose leadinguder the car from the (intake piping of the) engine to the brake booster. If your Skoda has an original one, sure it will be rotten and chapped.
First try this possibility
19:47:06
13.12.2014
13.12.2014
-> Christopher: The part dna69 posted a link to is a used one... shipping to canada would be around 40-50 USD. If that is OK for you, we (me, Bukaj, dna69 and maybe other people) can start asking resellers and such if they have a new unit in stock - but price for the unit itself is again going to be around 50 USD.
But realistically, there isn't much to fear from a used unit - there are only few parts that can fail and most of them are still relatively easy to get (I have most in stock in fact). I have a used unit in my basement that we pulled from a scrap car few months ago that you can have if we can't source a new one for you.
BTW, are you using your GLS as a daily driver, or just as a weekend car?
19:36:31
13.12.2014
13.12.2014
Christopher
Hi,
Thanks for all the replies.
dna69: yes - that's the part
www.iautodily.cz/posilova c-brzd-skoda-120-nd100084 2 85.html
Are you selling it? Is there any way you could find out postage to Canada?
Bukaj: I'd prefer the whole booster, but parts would be good too (buy a whole one AND rebuild the old one). I'm not *too worried* about shipping cost. My 120 has given me years of cheap motoring - I would be many thousands poorer if it was a Benz or a SAAB.
Dragon:
Thanks very much - that would be good too. I still don't mind shipping the whole unit from Czech Rep (or elsewhere in Europe). Yes it will be expensive, but that's the cost of owning an orphan car in Canada. As you can see though, it's a nice example, so I want to keep her going!
Dragon:
15:49:58
13.12.2014
13.12.2014
-> Christopher: I have a friend who's flying to Montreal in the middle of january, she's willing to bring some smaller parts like the membrane and such with her and mail them to you when she gets to canada. Not sure about complete servo unit, it's rather bulky and heavy and the capacity of her luggage is obviously limited.
15:24:36
13.12.2014
13.12.2014
-> dna69 - "zde je místo pro Vaši reklamu" :) : Jo, hodit tam membránu, gufírka a pár dalších drobností by mělo bejt v pohodě...
11:54:54
13.12.2014
13.12.2014
-> dragon_cb_cz:
Alternativa v podobě dílů, jak navrhuje Bukaj, by asi nebyla takový problém zabalit do kufru, ne?
08:12:23
13.12.2014
13.12.2014
-> dna69 - "zde je místo pro Vaši reklamu" :) : No, posilovač není zrovna malá a lehká věc a v letadle většinou hlídáš každé kilo.
Ale došlo mi, že teď v lednu má letět kamarádka do Montrealu, tak by mohla zafungovat... zeptám se.
00:55:40
13.12.2014
13.12.2014
-> Bukaj: A neexistuje i nějaká alternativa státního podniku? DHL bude drahý, ale co něco jinýho? Nebo nějaká firma, co tam jinak něco exportuje... Či někdo, kdo pojede alespoň třeba do USA.
14:34:59
12.12.2014
12.12.2014
Hm, podle kalkulátoru ČP nejlevnější varianta vychází na nějakých 800-900 Kč...
Uvidíme, jak se Chris vyjádří
14:17:23
12.12.2014
12.12.2014
-> Bukaj: Tak člověk si zvykne na ledacos, ale že by to byla nějaká výhra...
Já bych mu rád pomohl, ale bohužel ničím takovým nedisponuju. Maximálně bych mohl zařídit to odeslání, kdyby se někomu nechtělo. Jen to poštovný bude asi docela pálka.
09:13:27
12.12.2014
12.12.2014
-> dna69 - "zde je místo pro Vaši reklamu" :) : No, bez posilovače se jezdit dá, jde o zvyk...
09:12:18
12.12.2014
12.12.2014
Jo, taky jsem to tak pochopil.
O jednom novém vím, ale je na užovku, takže by se muselo vyměnit tlačítko - což je ten nejmenší problém
Hi Chris,
I know about one new brake booster in one shop, but it is for older model (1981).
There are some differences between new and old model of booster, the maim and the only you have to solve is the "button" (pos. 26 at the scheme).
Or I can ask some reseller, who could have a new type.
The last possibility is to refurbish your old booster with new parts - needed pos. (if damaged) - 2, 3, 8, 12, 20, 22, 23, (24, 25). Part pos. 3 you can refurbish, if it is scratched, by honing and polishing.
So, let us know, what way would you prefer
And for your easier selection - estimative price of new booster would be about 45-65 USD, parts needed for refurbishing your old one about 20 USD...
And I don´t know the taxes for shipping...
Hi Chris,
09:02:07
12.12.2014
12.12.2014
-> Syny: To máš teda blbý, tam už vochcávkou nedojedeš.
Asi taky záleží na tom, co je u tebe příští rok. Ten má totiž stejně jako ten letošní 12 měsíců.
A auto je bez něj asi nepojízdný, tipuju.
A auto je bez něj asi nepojízdný, tipuju.08:54:04
12.12.2014
12.12.2014
-> dna69 - "zde je místo pro Vaši reklamu" :) : Zalezi jak to hori, pristi rok budu mit dost mozna do Kanady spojku a nebo tam budu ja sam :) Ale ted to jiste nereknu...
08:27:43
12.12.2014
12.12.2014
Rozumím tomu dobře, že potřebuje brzdový posilovač?
Nemáte někdo doma nový nebo dá se ještě někde sehnat?
-> Christopher: Hi Christopher! Is this what you want?
www.iautodily.cz/posilova c-brzd-skoda-120-nd1000842 85.html
03:26:14
12.12.2014
12.12.2014
Christopher
Hi,
I'm in need of a Brake Booster/Servo for an 86 120GLS. In new or very good working condition. If anyone knows of one for sale, or an honest parts guy, please let me know.
I'm all the way in British Columbia Canada. I have most parts I need, but my usual parts guy can't get one, and they have not sold Skoda parts here since 1989!
Thanks,
Christopher
www.skodacanada.ca
Ahoj,
Já jsem v nouzi brzd / Servo s 86 120GLS. V nové nebo velmi dobrém stavu. Pokud někdo ví, že jednoho k prodeji, nebo čestný dílů chlap, dejte mi prosím vědět.
Já jsem úplně v Britské Kolumbii v Kanadě. Mám většinu částí, které potřebuji, ale můj obvyklý části člověk nemůže dostat jeden, a oni nemají od roku 1989 prodala Škoda díly zde!
Díky,
Christopher
www.skodacanada.ca
Thanks,
Christopher
www.skodacanada.ca
Ahoj,
Díky,
Christopher
www.skodacanada.ca
