Eidy / Kóča Eidy / Kóča
* Olej Millers 10w60 NT.
22:45:36
23.12.2023
-> SO545: I když to pohladíš prstem, tak je to příjemný, co? 1
-> m8rinek: Hezký. I když vlastně nevím, co to v důsledku znamená. Byl bych radši, kdyby mi do jednotky na dálku přidal 2kOhm odpor pro snímač otáček. 1
19:50:07
23.12.2023
-> Eidy 20.12.23 23:35:20: tiez ku mne dorazila jedna hlava....od Zlina....raodst pozriet...a nielen
23:32:44
22.12.2023
-> Eidy: tak se hnuly ledy a vlastně jsi udelal dobře a to ani nevíš proč:)))
In connection with the approaching Christmas, in addition to traditional wishes, I would like to convey a gift to all EMU CLASSIC users. After a thorough analysis, the team has decided to make an extra effort to port the V3 software to EMU CLASSIC as well.
As a result, you will receive the same software as EMU BLACK (of course, with limitations due to hardware differences such as fewer analog inputs, lack of high-power H-Bridge, and CAN bus). Moreover, calibrations will be fully transferable between systems, and there will be only one software for both EMU BLACK and EMU Classic.
Starting from January, we are initiating closed beta tests for the V3 software, and if everything goes well, the software will be available as public beta in the early second quarter. I also hope that during this time, the V3 software version for the EMU CLASSIC platform will be available.
We strive not to forget our users who have been with us from the beginning, and I hope that this information will be a nice Christmas present for them.
Merry Christmas!
16:40:27
22.12.2023
MVM
-> Eidy: Hlava je topová,tak jako ostatně od Peťi vždycky.1 -> Bery: Nojo..ingot.. Ovšem na vině nejsou Alfa Romeo. To jen "my" starý babičky bereme na Techno, nutime je pracovat s moderní technikou.. To já jsem aspon ohleduplný a nutim je spolupracovat s Weberama..
Vy těm babkam hned dáváte plastiku a rvete do postele pornoherce, no někteří preplňovanyho...3
15:29:48
22.12.2023
-> Milan 136: To já samozřejmě vím, ale on furt říká, že nemá čas, tak já ho nechtěl otravovat. 3
-> Bery: No jo, on ten motor pořád vychází ze 60. let a na některých dílech je to znát. Ale Italové to vyřešili šibalsky. Dali tam strašně dlouhý vačky (299°/281°), aby se ta směs stihla vyměnit. 1
08:13:08
22.12.2023
Bery
byl jsem u Urbiho před pár týdny a držel ten hliníkový ingot v ruce a řeknu Ti, musela to být šichta pro tu směs aby se dostala do válce a ven.. jestli to spolu budete ladit, tak next level bude opět převodovka..
tak ať to jezdi, ja se mezi svátky konečně přesunu z baráku do dílny. po půl roce..
07:32:04
22.12.2023
-> Eidy 20.12.23 23:35:20: Ty sis to nenechal udělat u mulleta? 3 Ten by to určitě udělal 2x lépe a 3x levněji 1
00:41:24
21.12.2023
-> m8rinek: Black je bezpochyby super a umí nějaký kouzla navíc, ale pro moje potřeby zbytečný. A o změně SW/HW jsem neměl tušení.
00:26:50
21.12.2023
-> Eidy: o to nejde. Hw je u obou jednotek podobny. Blacka jen mene obsadis. Ale to co se pro blacka chysta je gamechanger a za minimalni penize dostanes opravdu profi jednotku.
Mam classic rad, sam ho doporucuji, protoze je prostě dostatecny, ale ted mi zacina davat black vyrazne vetsi smysl i kdyz pulku i/o neobsadim...
upraveno 1x, naposled 21.12.2023 00:27:33
00:19:35
21.12.2023
-> m8rinek: Black je na tenhle motor zbytečný. Už takhle umí výrazně víc, než potřebuju. Takže Classic. 4
00:14:28
21.12.2023
-> Eidy: emu? Doufam, ze jsi poridil Blacka, na pristi sezonu chystaji novy sw se strategiemi z PROčka..
Kabelaz udela Karel nejakou twistnutou paradu?
upraveno 1x, naposled 21.12.2023 00:17:38
23:48:27
20.12.2023
Spousta škrcení je odstraněna a vyplachování bude výrazně lepší. Úpravou prošly i ventily, které mají lepší tvarování. Zvetšení kanálů je očividné, ale kanály jsou i krásně napojené na sedla. Radost pohledět i pohladit. S tím vším se dostávám mimo schopnosti řízení motoru sériovou jednotkou a musí nastoupit moderní technika. To obnáší nová čidla/snímače, nová EMU a kabelový svazek. Už se těším, až to všechno složím a nechám si na "cinknuté" brzdě odměřit stráááášně moc koní. 3
23:38:36
20.12.2023
23:37:50
20.12.2023
Výfuk před (fujtajbl).
zvětšit Eidy / Kóča - obrázek od Eidy vložen 20.12.2023 23:37:50
23:37:30
20.12.2023
Slícovaná příruba.
zvětšit Eidy / Kóča - obrázek od Eidy vložen 20.12.2023 23:37:30
23:37:13
20.12.2023
23:37:02
20.12.2023
23:36:32
20.12.2023
Sací před.
zvětšit Eidy / Kóča - obrázek od Eidy vložen 20.12.2023 23:36:32
23:35:47
20.12.2023
23:35:20
20.12.2023
Říká se, že srdcem motoru je vačka. A já k tomu říkám, že plícemi je hlava. Takže jsem poslal hlavu do lázní. Výborné lázně jsou na Moravě a provozovatelem je Petr Urban. Takže nebylo co řešit a dnes se hlava vrátila ve výborné kondici.
zvětšit Eidy / Kóča - obrázek od Eidy vložen 20.12.2023 23:35:20
